Beogram 1600 speed problem
Hello!
My name is Philipp and i am new to this forum, but not new to the B&O World.
A friend of mine recently gifted me his old Beogram 1600 (along with speakers and amplifier).
Yesterday i realized that the turntable is slightly faster than 33rpm, i would say about 1-1,5 seconds per minute.
Does anyone know if this is normal? Ist there any way to fine adjust the playing speed? Or is it a mechanical issue?
The beogram is in an overall good condition, everything else works fine!
Thanks in advance for any answer!
Kindest regards from Germany
I hope its ok to bump this one.
Could be an incorrect belt.
I believe these have the pitch adjuster above the rocker switch.
There are free phone apps that can be used for speed adjustment or get a strobe printout from vinylengine.
Thank you very much for your answer again!
“Sadly“ i have the version without the pitcher above the rocker switch. Thats why i thought that maybe there is something like a fine adjustment inside the turntable.
I also thought that the belt might need a replacement...but how do i get inside the device? With my other beogram, i just needed to lift the platter but this one cant be lift somehow...like its stuck or something. Any advices?
kindest regards
 Yes, there is an adjuster inside all the info is in the service manual
Best regards Alistair
Hi!
Thank you very much!
Sadly i cant find a manual for my beogram? Is there anyone who could probably send my a scanned manual?
Also do you know how to open the beogram?
Kindest regards
Bump
““Sadly“ i have the version without the pitcher above the rocker switch. Thats why i thought that maybe there is something like a fine adjustment inside the turntable.”
I have never seen this model but I should imagine it’s the same as the normal 1600 in which case
There are 2 trim pots inside for the 2 different speeds
There are lots of manuals on the site for silver or gold members,
The 1600 is not here look for the 1102 a very similar model
(if it were mine I would also change the belt)
Hello!
Yes, i want to change the belt as well! But how do i get inside the turntable? Just lift the platter or is there anything i need to "unlock"?
I also added some pictures of the turntable.
link
link
Kindest regards
Philipp
