Beogram 1500 type 5714
Hello
Approxmately evry second time I press 33 it runs with near 100 rpm. 45 always runs normal. The mecanical speed-switch on th print works normaly.
Please help.
Hans Petter
Common problem.
The belt is slipping. The motor then accellerates too easily and the electronics lock it to twice normal speed.
Cure: replace the belt.
I can supply a correct belt, if you don' thave one.
