Beogram 1202 tonearm cueing
Hi all Just a quick question, my beogram 1202 when set to automatic cue is beginning the record half way through, is this just a unbalanced tone arm issue?? Thanks
No it isn’t. Just set it on 30.
Hi again Jacques! 😕The TT is set to 30 but keeps starting play in the middle of the record?
Then something is off. Was the tonearm forced at some point? What does it do on 25 and 17?
Automatic is not a setting. Thats just a label.
turn the knob clockwise to 30cm and Press lift.
martin
It’s possible that the tone arm was forced in the past as I haven’t long had the TT, will see what it does at 25 and 17 and get back to you probably won’t be till tomorrow😕
Hi dillenThat is what I done but still the tone arm lands half way through the record to play 😛Automatic is not a setting. Thats just a label. turn the knob clockwise to 30cm and Press lift. martin
Is the tonearm parallel to deck side when in rest position
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Hi looked at the TT again today and took photos to help, so photos from top are starting playing position from 17,25,30 Login to view image Login to view image Login to view image
Yep the tone arm is parallel to the Deck Login to view image
