Hi all, I have just purchased a very nice Beogram 1202 which appears to be in very good condition, does anyone know where I can get hold of the manual, I'm pretty sure it's fairly simple to use but I am confused at what the dial around the lift switch does also the dial on the bottom left back. It seems as if this is only playing in 33rpm. How do I change speeds 33rpm to 45rpm ?
The below is what happens when moving the dial around the lift swich
When I the dial around the lift switch in the off position then press lift the tone arm lifts up and move over about an inch and a half inside a 12" vinyl and drops an plays 33rpm. I press lift again the tone arm lifts and platter stops.
When I have the dial turned one click to the right the platter starts to spin, I then press lift, this moves the tonearm to the beginning of a 12" vinyl and plays 33rpm. I press lift again the tonearm lifts and the platter continues to spin until I move the dial one click to the left in the off position.
When I move the dial two clicks to the right the platter spins then stops, I then press lift, the platter spins and the tonearm lifts and moves over to the beginning of a 12" vinyl and plays 33rpm. I press lift again and the tonearm lifts and the platter stops spinning.
The tonearm does auto return on all three setting when finished playing.
Any advice would be much appreciated
