Am I goin' crazy..?
After I have recorded about 30 tapes or so, I found out that my Beocord 3300 had recorded them low on one channel. That sucks;-)
I tried my 4500 on another Beomaster...same result, though less difference between channels. I bought a 5000 so that I could monitor L and R levels on a third Beomaster, but the problem still occur.
When using the Beocord 5000 I can see that both levels are equal when recording, but when I hit Play then left channel is weak!! I have 3 different setups and all do the same. The Beocord 5000 had been serviced by its previous owner. How is this possible? I tried asking in a Danish B&O forum, but no real response other than it sounded weird. I'm no Technician, but have recorded tapes on other Cassette decks without problems.
When recording I use my MacBook with a MiniJack to DIN cable (tried several) connected to the Beomaster and the sound is perfect with equal balance on both speakers when playing. All the Beocord's plays fine with pre-recorded tapes, but when I hit record....I'm loosing my mind;-)
