Recently got a hold on a serviced Beocord 8004, but I can't help but wonder if it's normal for the metal light to come on whenever I insert a Type 2 tape? Also when recording onto type 2 and 4 cassettes I lose some treble compared to recording on type 1 cassettes. Metal is not so bad until I enable Dolby C which is no problem when recording on type 1 but falls completely flat when used on type 4. And whenever I record on type 2 cassettes it's like it uses Metal bias so the treble aren't as clear as I know a TDK SA-X tape normally to be. So I was wondering if anyone have experienced the same and what to do if it's a malfunction?
Beocord 8004 tape select problems
