hi I am replacing the 5 belts on a 5000 beocord t4715 .ive replaced 1 off the counter belts on the pully on the bottom of the unit but don't know were the second counter belt goes?. does a member have a picture to were the belt goes thanks
beocord 5000 t4715
It goes from the pulley at the side of the drive to the wheel at the counter.
It is to be fitted when/while closing the top board.
hi martin ive replaced the belt pully at the side off the counter .looking at utube it onley shows that belt ? being change that is why I would like to see a picture so I can get my head around it .regards shaun
Did you watch Beolovers video?
hi martin yes it shows the belt to the outer pully on the side .which IVE done does .but it does not show were the other counter belt goes shaun
