Hello,
I just replaced the belts and a fusible resistor (R20) on a Beocord 5000 (thanks to Martin). Everything tested ok. Played a whole side of cassette without any issues. Put it in standby. 30 min break. Switch on and play cassette - Noticed that the LED for VU meter were not lit for Left side. Right side was OK. music was playing from both speakers. So I switched off the unit, switched on again but this time there was no sound from speakers when cassette was played.
So the player is playing the cassette. All tape functions work ok. The connected BC9500 switches on when beocord 5000 is switched on and responds normally.
Two visible issues -
1. No sound on play.
2. VU meter - All LEDs come ON when cassette is playing. The LEDs go off if tape is switched off.
Any help/guidance will be appreciated.
Thank you !!
