Beocom Voip
Love the idea of VOIP but not the awful handsets or sitting at my pc to contol things
Just linked up one of these to my Beocom PSTN (older style with 3 Beocom 2 and 3 Beocom 6000 attached)
The Beocoms also work with VONAGE (VOIP system in N.AMERICA).
Hi there,
that sounds very interesting and i would appreciate if you could explain me exactly how you have connected the cables.
do you connect the same pstn to both main line and pc?
do you use a seccond pstn for skype ( pc ) ?
Can you share your connection; pictures and explenations on how connected?
I assume you can connect a Beocom 6000 directly/only into the adapter. Possible to pick-up for 10GBP? price on homepage is ~$60; cable looks propriteray.
Klas
Wanting to catch-up with the marching leader
If I have read it correctly this is some kind of adapter that plugs a PSTN phone into a PC.
 What I would be really uinterested in is a box that lets me plug in a normal phone in and make VOIP calls without needing to go via the PC. Do such things exist?
 Simon
The best decription of how to conenct can be found here
