Beocom 6000 not registered
Tried to register a handset to my 6000 base (Mk1). I get "searching for base" and then "not registered"
This handset was previously registered to the base but having removed the battery for a while and then re-connected it displayed "No signal". The forum advice was to remove the base from the handset's memory and register it again. The base is open so why doesn't the handset find it and register?
Thanks for further help
David
Obvious perhaps but I assume you've pressed the little button on the pstn to allow the 5mins to re-register the phone?
Yes - I did 'open up' the base by pressing the button. I have two other handsets working fine with this base and don't want to do anything to prevent them from working. I've never had this problem before so I think the offending handset has a fault which has developed in storage. It was originally dead after been left out in the rain but then came back to life after months of storage in a dry warm environment. It worked fine and then began to discharge batteries faster than normal. Maybe time for another handset or a service kit?
David,
There could be several reasons why your base is not registering including:-
  • Faulty battery which provides enough power to run the phone itself, but is to weak for transmission.
  • You have 5 phones already registered with teh base even if you only actually using two.
  • The phone itself has a fault.
Given that you have said that the phone appears to discharge batteries faster than normal tends to lead me to believe that it is an electronic fault with the phone.
I would suggest updating it to a Mark II (modified) phone as discussed in other threads, PM me for information.
Thank you Keith. I will send you a PM
