How do I remove it? Slide, pull? I can't find a post about this specifically, only about removing the main casing using a credit card.
Help!
Help!
Press down on the battery cover (adjacent to the LED lamp on the rear cover) and slide it towards towards the bottomedge of the phone. There is a small plastic retaining clip, as soon as that is clear of the body of the phone it will lift off.
Opman
