BeoCom 6000 Battery Cover
How do I remove it? Slide, pull? I can't find a post about this specifically, only about removing the main casing using a credit card.
Help!
Press down on the battery cover (adjacent to the LED lamp on the rear cover) and slide it towards towards the bottomedge of the phone. There is a small plastic retaining clip, as soon as that is clear of the body of the phone it will lift off.
Opman
