I've read threads about this, but haven't found a solution that works. I bought a BeoCom 6000 a couple of years ago (Pyramid base with beoline built in) - this isn't an MK anything .. under battery just says:
BeoCom 6000
B&O 1070046
Serial no. 107004688158315
Made in Denmark 99W37
© MCMXCVII Bang & Olufsen
I read somewhere that you could pair this unit to a beoline and it's base would simply function as a charger. This unit doesn't find the base. I have an MK model that finds the beoline with no problem, so I know it is open and in registration mode. I tried factory reset of my 6000, which does reset, but still will not find the new beoline base. The red line on the base is blinking...so I'm assuming there must be different flavors of 6000's even without the MK designation and this is simply not compatible...is that correct, or is there something else I can try?
Beoline info:
Beoline 1084149 US
2003
Serial: 18294481
P.S. B&O needs to hire some new "name thinker uppers" :)
