BeoCom 6000 - Speaker problem
Hi Michael.
I have posted your speaker this morning. It should arrive on Monday or Tuesday.
Andy T.
Hi Andy
Thank you so much - looking forward to recieving it.
I am not sure about the directions though.
I have never removed even the battery before, so could you explain it once more, even more detailed and slow?
Or is the any other guides/instructions on the web?
Thanks again.
Hi Andy
The speaker come today - thank you so much.
But I am in trouble already, before I get the case opened.
I can pull out in each side and lift them, but the back is still stuck - should I slide it off or something else?
Thanks again.
To get the Beocom 6000 case open you will either need a tool as shown in the picture or a very thin bladed blunt tool to slip down the side.
After you have removed the two screws at the bottom of the battery compartment, carefully slip the tool both sides at the top of the battery compartment only allowing the back to move apart a couple of mm (milli-metres) The two clips at the top (shown, but not mark in red in the picture) will effectively act as the hinge for the back. Now slip your tool in at one of the top holding clips and it will start to come apart.
The the two sections come apart be careful with the top two holding clips which are effectively acting as a hinge as you remove the back as they can break off if to much force is used. As you remove the back, the wires for the speaker will need to be unplugged, its just a push fit.
You're up early Keith, and beat me to it!
I just took some pictures to show the credit card method.
Nowhere near the quality of yours, but here goes.
2
Corner in first.
3
Roll it round and slide it up
4
Same on the other side.
5
And on the top. There are two locking tabs here, so I used a wide piece of card.
6
Once they're all in, it should tease apart starting from thw battery compartment.
Ignore my other hand, that is the remote for the camera.
