Beocom 6000 - European compatibility issues?
Very good Phil,
We now know for sure that the problem is with the line driver in the France Telecom Exchange which we had both really thought was the case from the begining. So we must both wait another 7 days for this more senior engineer hopefully to change the line driver.
What your tests also show is that whilst the fault is at the exchange, the BeoCom 6000 does draw more line current than most other makes of phone because even with the faulty exchange line driver, the voltage drop is greater with the Beocom 6000, this is basic Ohms law in a DC circuit which is Volts = current x Line resistance where line resistance is normally constant..
Looking forward to hearing that the problem is fully solved in 7 days
Keith..
Hear hear Keith. We've ben watching this story since the old site I think.
We wait with bated breath!
Andy T,
Just to keep you up to date. I had a conversation this morning with a France Telecom engineer and he agreed to install a new card in the exchange...... two minutes later and the problem is solved. I now have a steady -15 vDC under load. It's taken an age to get it sorted but it's a happy ending.
Thanks for all your help.
Nice one Phil!
And glad to hear the problem wasn't related to a B&O product.
Hasn't Keith been a star?
Andy T.
Hi Andy, he certainly has.  It's important to have a few good techies in any forum which performs any useful function (other than idle chat).
Thanks again Keith.
Can BeoCom 6000 mk1,  bought in England, work in Italy? Thanks
Keith Saunders wrote:
From a PSTN line view point I think the UK, French & German Basestations are the same. They do each have different type numbers however which you may wish to check.
UK Type 0636
Germany Type 0632
France Type 0639
Keith..
Hi Keith,
this is a relaunch of the old theme.
I´ve brought a BC 6000 Mk I with it´s pyramid base station/loader, manufactured about 1999 in Germany, to France now. The handset has got a software update on 2.50, but the base station is original.
At first the complete set said nothing at all, but after I´ve changed the wiring in the RJ11 plug in, the set worked for in- and outgoing calls, but there is no caller ID visible. Instead there is a flashing black line.
CLI is active, because on a testwise connected Siemens Gigaset it is working. When I connect the 6000 handset to the Gigaset base station, there ist no caller ID, too.
Is it possible to "update" the base station for use in France with CLI, or what to do?
Additional question:
If not for the MK I, is the MK II with it´s small pstn base usable in whole Europe with full usability?
Thanks for answering.
