Beocom 4 "No Contact with Base"
For some reason my Beocom 4 ceased to work and now displays on the screen a "No contact with base" error message.
I have switched power supply, replaced the battery, tested different RJ-11 sockets but no luck.
Any ideas ?
Hi, sometimes the contactors at the bottom of the 2 units become loose and you get this message, it happened to me some time ago, I just had to use a tweezer to make the 2 contactors from the handset closer & in better contact with the base, and it worked again.
Maybe it's another issue, but on mine the contactors were the only problem..😛
Have you fixed the problem yet? any suggestion on disassembling the base to get it fixed?
