Is the RJ11 (male) to BT (male) lead used on this phone non standard? I am getting "no contact with base" using a new RJ11 (4 pin) lead after the original went missing.
Thanks for any help
David
Thanks for any help
David
To use my Beocom 6000s in UK I use a RJ11 to BT 'crossover' cable like this one: link
You need RJ11 pins 3 & 4 to go to BT plug 5 & 2 respectively, hence 'crossover'.
EDIT: I just checked and this is the exact one that I purchased as it only needs the 2 wires: link
EDIT2: And here's one that's in stock! 🙂:
Thanks for the explanation and links. "crossover" is not something I was familiar with. I bought "1m RJ11 to BT Cable Lead FAX Modem Telephone Phone Plug BT Socket 4 Pin Black". No good at all.
David
