Hello
My Beocom 2 keeps reverting to 'clock has not been set' status. At which point I reset the clock, date etc and then it may work again for a while before it reverts again. Please help!
Hello
I don't know! However, I have found THIS thread with similar problems. If you get no other replies to this then it may be worth contacting Kingstreet if you're within reach of them or emailing the other person that had the same problem.
If you find out the problem, please do tell us on here to assist anyone else that experiences the same.
Steve🙂
Thanks for this - I may try to see if i can get the batteries updated in the first instance.
