beocom 2 base station registration issues
Hello,
Just got a beocom 2 that I would like to register to my base station ( A beocom 6000 pyramide).
The beocom 2 handset does not find the base station. Now the beocom 2 is a UK model and the beocom 6000 base set is from the US.
Would there be an issue with different country versions of FW?
Regards
Peter
Peter,
Have you triggered the base polling by pressing the centre button between the two brass phone contacts on the Pyramid base ?
Hello Keith,
Yes did so. As test I also re-registered one of the beocom 6000 handsets.That worked fine. The base station is picked up within seconds.
The 6000 handsets have unique names and numbers 1-3. Do I give the beocom 2 handset an number before registering it?
 Regards
Peter.
Peter,
Whilst the Base station was from the US, was the Beocom 6000 also from the US or was it a UK version. The US handsets have different firmware in them.
Hello Keith
The Beocom 6000 base station and handsets are from US , the beocom 2 is from the UK.
Regards
Peter
Peter,
In both the handset and the base there are "Country Parameters" setup and when both the handset and when the base and handset have the same parameters there is no problem, but when they have incompatible "Country Parameters" is where you get problems and in my view that is your problem. So, to change these "Country Parameters" or update the firmware in the base or the handset you will need the help of your local dealer.
He can attach a jig to the phone and base and update them via a software tool in his PC.
Hello Keith
Having googled around a bit I learned that the frequency for DECT in the US is different from the one in Europe. US being 2.4GHz and Europe 1.9.
Now when I check the handset version no, the end bit lists 2G4, seems to indicate the beocom 6000 set I have works with 2.4 GHz frequency.
What is the frequency used in Europe by B&O for a Beocom 6000 and 2? If this is different from the 2.4 it will never work together, right?
Regards
Peter
ANYBODY
COULD YOU HELP US PLEASE
JUST MOVED TO SPAIN FROM ENGLAND AND HAVE FULL SET OF BEO6000.
CANT SEAM TO GET THEM TO WORK OUTHERE EVEN THOU THEY ARE IN FULL CHARGE.
COULD YOU GIVE US SOME ADVICE PLEASE
REGARDS
BAZZA
Hello
What type of cable are you using to connect the base station to the 'network', i.e. the telephone connection socket in the wall?
Regards
Peter
HI PETE
WE HAVE A 3WAY LEAD THAT SAYS POWER LINE ON THE BOTTOM AND APP ON THE TOP! ONE CABLE GOES FROM  POWER LINE TO SOCKET IN WALL.THE PHONEBASE IS INTO THE APP SOCKET AND THE THIRD CABLE GOES FROM THE OTHER POWER SOCKET TO A LINKSYS PHONE ADAPTER THAT CONNECTS TO OUR BROARDBAND
MUCKED UP I KNOW
THANKS FOR YOUR REPLY
REGARDS
BAZZA[:'(]
