Beocom 1400/1 IR module…
Hi guys,
If anyone remembering, I do like to refurbish old Becoms for more modern use.
After bluetoothing a Beocom 6000, I'd like to wire the handset of an Beocom 1400 to my stupid-smart-phone.
All this to be able to lower the volume of the Beosound when a calls come-in. Anyway, containment…
My question is, how is the IR module powered? The base seems to be independent from the handset.
So is it battery powered or did I miss something? Pictures on the web are unclear about that and manual I've found don't seem to say much either.
I dont own the Beocom right now, just looking for one with IR module, but would use your advice before buying second hand.
Thanks to all.
I had one quite a while back and it had a battery compartment with 2 or three AAA batteries
3 batteries, 4.5V dc.
I wired one from a Beocom 1600 like this once as a hidden volume control under my dining table:
Hi Guy!
😁 Did you wire the Video button as to eject unwanted guests from their seat around the table?
Thanks you both for your answers!
There is a secret "battery compartment" in the tablestand .....
.... and in the wallholder .....
Thank you Beozip, useful information indeed! I would certainly have not find that by myself!
As a side question, do anybody know how to open (dismantle) the handset? Thanks.
There's no easy way because it's glued together.  You basically need to 'break' it open carefully.
There's a picture here of an opened one:
Thanks.
Great help but bad news. Right now I have a lead on a said "brand new" one in box. Would be a shame to start by hurting it.
Yes I couldn't do that to one in really good condition!
Have you considered a Beocom 1600, 2400 or 2500?  These have most of the electronics in the base hence would be easier to modify - plenty of space!
How/where were you planning to fit the BlueTooth battery/power for a Beocom 1400/1401 modificiation?
