Beocenter to Beolab 1
Guy's,
Been a while since my last post...............
Relighting my B&0 passion and have recently took ownership of a pair of used Beolab 1 speakers.
Don't have any B&O amps with powerlink at present.
Is it possible to connect my Beocenter 9000 to the labs?
I've noticed there is a pre amp rca connection under the cover.
What cables (etc) would i need
Thanks in advance
Hi nikeyboy,
No problem! You can easily connect from the pre-out sockets on the back of the Beocenter 9000 to a pair of Beolab 1 speakers using the cable in the link below:-
http://soundsheavenly.co.uk/bando-rcatolab.htm
You would need to select "Beolab (RCA)" to get a stereo RCA to stereo RCA version of the cable for your Beolab 1 speakers and you would also need to switch both speakers to Line mode using the small switch underneath.
Kind regards,
Steve.
