Hello to everybody,
can anybody describe me how to start a CD in a Beocenter AV5 (which is in a linkroom) from the mainroom?
Thank´s and regards ...
Patrick
Hello to everybody,
Patrick
the command LINK CD should do the trickHello to everybody,can anybody describe me how to start a CD in a Beocenter AV5 (which is in a linkroom) from the mainroom?
Patrick
thats is not possible.. you can NOT connect to sources in Linkroom! only sources from mainroom then you are in linkroom
right, I got it the wrong way aroundHi, thats is not possible.. you can NOT connect to sources in Linkroom! only sources from mainroom then you are in linkroom
