Can anyone please advise me if I can run Amphion helium 520's off a beocenter 9500? The speakers are 4 ohm 10-150 watt input rating / 90db sensitivity. i have a feeeling that the amp will not be strong enough or overheat. Thanks in advance. Don't wan't to ruin the 9500 as i just had a new CD mechanism installed.
beocenter 9500 with 4 ohm speakers.
Hi Rex,
The speakers described should be no problem at all, in my opinion.
Thanks Graham.
I will give them a go.
