beocenter 9500 with 4 ohm speakers.
Can anyone please advise me if I can run Amphion helium 520's off a beocenter 9500?  The speakers are 4 ohm 10-150 watt input rating / 90db sensitivity.  i have a feeeling that the amp will not be strong enough or overheat.  Thanks in advance.  Don't wan't to ruin the 9500 as i just had a new CD mechanism installed.
Hi Rex,
The speakers described should be no problem at all, in my opinion.
Thanks Graham.
I will give them a go.
