I know it's about the Million Times asked for the Co.de for a Beocenter 9500
With a new Lithium Battery tested.
I've read already to:
Plug in the Center
Type 1271 with Beolink 1000 or Beolink 4
Unplug the Unit and plug in after about 3 seconds.
So far so good but it does not work this time.
Tested other Codes like 1270, 1207
Have already tested several BL 1000 and BL 4, no succsess.
Checked already the IR Signal to uPc board IC3 PIN 3 > Ok, signal clear present. Measured with Oszillscope.
What can cause this behaviour?
Hope to get an answer or a solution for that Problem.
Kind regards
Christian
