Beocenter 9500 & equalizer or another use of the in/out
How connect and use an equalizer on the Beocenter 9500.
Welcome to the forum!
You'll need a special connection to the DIN LINE IN/OUT socket just above the POWERLINK 1 socket on the rear connections panel.  Normally the IN/OUT connections are bridged with the plug that is usually inserted.
EDIT:  Checked the service manual and I think pins 4 and 1 are R and L out respectively, whereas pins 5 and 3 and R and L in.  Pin 2 is ground.
Can't think why you'd need an equalizer though!
Thanks.
I thought so, but wasn't sure.
Dont need an equalizer, but i have a Missing Link Musical Fidelity (Tube).
Just want to check how it will sounds.
