Beocenter 9500
Can someone advise me on the thickness of double sided foam tape i need to buy to re glue the glass panels on a 9500. The company i normally use for tape have offered me 6mm wide tape in either 1mm, 2mm or 3mm thickness (depth).
Any advice would be much appreciated.
Regards,
Darren
Search eBay.co.uk there is beocenter per cut glass tape available....
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I took advice from the old forum and simply used superglue gel - the gel is less messy than normal superglue.  I left the old tape in situ and saved myself a lot of time in tape removal/cleaning.  I did 2 BC9500s a couple of years ago and have had no problems.
1mm thick & 6mm wide.
Where are you located? I have some spare if you want it?
Chris.
Thanks for all you replies and thanks for the offer and description of the tape Chris. I'll order some 1 mm tape tomorrow - it will be handy to have a full roll in case i screw up but thanks for the offer Chris.
Regards,
Darren
