Can someone advise me on the thickness of double sided foam tape i need to buy to re glue the glass panels on a 9500. The company i normally use for tape have offered me 6mm wide tape in either 1mm, 2mm or 3mm thickness (depth).
Any advice would be much appreciated.
Regards,
Darren
