Beocenter 9300
I suppose that by removing the battery, everything is cleared from the memory. One could then just put the original back. There obviously must be a way to also clear it using the remote.
Hi Bensa
That's what I ment by chanching the battery as I have had a few cases with strange behavior as the battery was low and there was no indication from the display.But I will not make more comments on this issue as there are a few wise guy's who seems to know better.
regards
jan
Hi Jan
I did realise that is what you meant. 🙂
Any advice or suggestion is always worthwhile!
