I have a Beocenter 9300 that automatically switches itself off after about an hour, but there are no programmes in the machine! Can anyone advise how to clear what appears to be a phantom programme.
John
John
Hi
I think it has to do with the timer/clock funcktion try to unplug it from the mains in approx 5 minutes and plug it in again.ore change the lithium battery inside the 9300.
regards
jan
Hi John
Oh! and welcome to beoworld
regards
jan
Hi
regards
jan
@ birgerbum
Your universal cure for problems with BC9000/8500/9500/9300 seems to involve changing the lithium battery!
I have direct experience of many of these fine systems and I have never had to change the lithium battery.
Can you quote examples of what has actually been cured by this action or do you simply have shares in the manufacturer of lithium batteries????
Always thought that if the internal lithium battery needs replacing the the word "code" is shown on the display?
Craig๐
Correct, I believe Craig. At least, that is what I have read in one of the service manuals, Can't recall which one!
Hi Graham
That was just a suggestion as I once have solved a bc 9500 with somewhat strange problem by chanching the battery.
regards
jan
Hi Graham
A nother thing that came to my mind why don't you suggest a solution as you are expirienced with these machines.
regards
jan
Hi Graham
regards
jan
I suggest deletion of all preset programs using the built in test menu as outlined in the service manual which can be downloaded from this site.
Think it is the 9500 Graham, but I may be wrong.๐
Craig๐
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
