BeoCenter 9000 servo board C2103 Sites that can be purchased?
hello
Now the problem is that the Beo Center 9000 product does not play the CD, the door opens and the servo board C2103 needs to be replaced.
Please tell us the site address where you can purchase.
I can supply the correct capacitor kit for the servo board in your Beocenter 9000 - including the correct component for C2103.
Email or PM me.
hello
CDM 2/29
I just attached a photo by email. Please check once.
You keep posting the same question.
You cannot buy a new disc drive for Beocenter 9000 anywhere - but capacitor kits are available for most servo board versions, and that is where most
problems are. (DON'T touch the laser current adjustments! or the repair job will be much bigger).
To see if a kit is available for your servoi board version, I asked for a photo of the servo board.
You sent me only photos of the CdM label and the disc clamp.
Thank you for answer.
I'm not sure which part to shoot because I don't know the product.
If you can see where the part of the picture I sent is, can you mark it?
I sent a few photos attached today. Isn't that the picture?
I received no photos from you today yet.
The servo board is the board that has capacitor C2103. It sits at the underside of the CD drive.
Should I open the cd drive and check it?
Take out the complete CD drive.
Take a photo of the numbers found in the corner of the board that sits under the drive and email to me.
Mail sent again. please check
