Beocenter 6
hi all
if you have your main room system (TV) connected via ML to a beocenter 6 in the bedroom can you access the DAB on the TV in the main room
is it also accessed via the radio button
i have no audio device
does BC6 have stb for sky digital ?
Does the BC6 have the internal radio module? If yes you will need to go to the radio settings on the BC6 and turn off the internal module.
You will also need the BC6 set as a link product
My BC6 does have the stb for sky (digital and sky+)
Christian
sorry what i meant was the DAB in the BC6 can it be accessed by other devices on the ML.
Just spoke to my local dealer
i would not be able to access the DAB from a link room in a main room
Shame as now i will have to buy a beosound with DAB
