This question is for a Beocenter 2500, but would also apply to the 2300/3000/4000/3200 units: if you want to use the piece with a conventional amp and speakers (the horror!) how would you set this up, how would this be routed? is the signal coming from the aux jack then fed into the amp?
In regards to a beosystem 6500/7000: is it possible to have a non b&o amp and speakers connected (full system functionality but with a larger outboard amp)?
