I know we have cover this issue many times before.
But I can not find the nearest answer for this.
When I press play on CD it spinns for 2 sec then stops.
Is it the only way to replace the laser unit??
thanx.
thanx.
This type!?
I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty.
Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
I have clean it.And got it work....but when I change to Radio and back to CD it spinns 2 sek then Stop. If I just touch the lens, not glas) it works again😂I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty. Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
