Hi guys!
Can anyone help me out on what is probably a simple question? I have bought a used Beocenter 2300, and paired with my Beolab 3's I find that the sound is a bit thin. It's like the Beolab 3's don not reach their potential. Things get even worse when audio is streamed to the set via Apple Airtunes or from Spotify using Airfoil. Even when spotify is set at high bitrate on a premium account.
Anyway - I have found that enabling Loudness at least helps a little bit. Does anyone know how I set the 2300 to have Loudness constant on? I have no problem turning it on from day to day, but it seems to disable itself when the Beocenter is put to standby.
Also. If anyone has ideas about how to match the two pieces (BC 2300 and BL 3) better than just hooking them up it would be highly appreciated!
Thanks!
