Beocenter 2000 tape deck questions
Sorry disregard last reply, I just gave it another go and it started working! Didn't do anything different, don't know why it just started working. Only thing that doesn't work now is rewind
All three belts correctly fitted?
Sorry for the delay there, was trying to fix it but alas.
As it turns out, the belt for the rewind mechanism has also perished. I've been trying to gain access to the two wheels to clean the gunk off and see about fitting a replacement, but I can't find a way to get at them. This system seems much less user-friendly than the home-grown Bang and Olufsen mechanisms
Does this help ?
Regards Biggles
