Hi guys,
I know the Beocenter 2000 is not looked upon very favourably due to its outsourced manufacturing and comparatively lower quality, but I recently bought one just to get the cartridge for another turntable in need, and thought I'd give a go to restoring the rest of it for fun.
Half of the tape player's buttons had fallen in, it turned out the posts had all broken and fallen away, which will be an easy enough fix.
My main two issues however are:
I can't find a service manual anywhere and I have absolutely no idea what size the belt is supposed to be. The belt had completely disintegrated into gunk and I can't find any information online about what the length for a replacement should be.
Also arising from the lack of a service manual - when I was taking it apart, I unscrewed this switch from somewhere, and cannot for the life of me figure out where it came from. Login to view image
I am guessing it has something to do with the record button? There is a similar switch screwed in at the other side for the pause button, but there's not a similar place for it to go that I can find:
I know that this was a cheap mechanism from an unnamed Japanese company, but I don't know anything about tape player repair, so hopefully it's a relatively simple fix and maybe a more common build than most Beocords?
Any help would be greatly appreciated!
