Hi all hope you can shed some light on my issue. Without listening to my misses and getting some professional advice before buying I have brought a beocenter 2 and 4 xBeoLab 6000 speakers.
Initially I got the beocenter 2 and 2x BeoLab 6000 speakers which worked fantastically. This weekend decided to get two more BeoLab 6000 speakers and went to set the up.
When i brought the beocenter I was given what I thought was a splitter for the speakers that take 4 in totaly by running to one of the speakers and then from that speaker to the next one. For the two original two speakers that worked fine. But adding the next two speakers in the same way they do not work. I have swapped over all the cables and the speakers but what every I do they just do not work as 4.
Attached are three images that I hope will help one that shows the speaker "chaining'. Second one the cable that I believed was the speaker splitter and one of the unit. Hope this makes sense.
Many thanks Paul
