Hello (again) everyone.
I came home to find my Beocenter 2 flashing its red LED, it is otherwise unresponsive, and doesn't request the PIN as if the power had been disconnected - just flashed the LED with nothing at all on the display and doesn't respond to either the front panel or the remote.  I've tried disconnecting it from the mains for a while, but it made no difference.  Nothing has happened to it, and no-one's touched it.  Any ideas?
Ray
