I recently bought a table stand for my BC2 (many thanks to LifeStyle AV) and so disconnected the unit whilst I fiddled with the screws, etc.
Now when I re-connect the unit the indicator light becomes illuminated so power is OK. But I can't get anything to work, either manually or using the remote control. If I touch any of the "buttons" on the unit itself (e.g. RADIO) the indicator light goes off for about 10 seconds before coming back on.
The main display on the unit remains blank and therefore I do not believe it is an issue with a pincode. Accordingly, any advice on how I could re-boot my BC2 would be gratefully received.
Cheers, Mike
