Beocenter 2 connected to Beosystem2 - unable to pull up CD or radio on the remote.??
I will not muddle this query with my already confused B&O head  - my beocenter is connected to the AV Scart input on the Beosystem2 - in the Connections menu I have AV set to DVD so rather unsuprisingly when I select CD on the Beo4 it ignores it (same for radio). My Skybox is in the Vmem scart, with a Beomedia on the VGA input.
How can I change this to allow me to access the CD and radio from the remote? Do I need the Dig out
 Many thanks
Mark
Are your option settings correct? Assuming the speakers are connected to the BS you need to switch the BS to option 2 and the BC to option 0 if I am not mistaken.
I think if the Beosystem is in option 1 and the BC 2 is in option 0 which it goes to if no speakers are connected then it behaves like you describe - I leaving the TV/Beosystem in 1 and the BC in 0 which is an invalid combination.
This all assumes your speakers are connected to the BS.
http://www.beoworld.org/beotech/mlsetups.htm
Here is how you change options. I hope I am not too far off, this is new for me but my BV8/BC2 behaved similar when I did the initial setup.
Cheers
JK
Hi JK
Huge thanks for that - absolutely spot on even with your assumptions!
All working well now
THANK YOU
Mark
