Hi all, I have a Beocenter 2 which for some reason the clamper is intermitent at opening. I press the load button the wings open but the clamper does not, neither do the lights come on. I can hear the motor and if I press the load button again then the clamper opens and closes followed by the wings closing. I believe this is to do with a belt under the right door, but I am unsure how to access this. I tried to take the back off with the four brass allen bolts but these did not seem to want to come out, they loosened slightly then got tight. I did not won't to force them out and brake anything so left it as is as I am unsure if these were the right bolt to remove. Any help on this would be very much appreciated
Thanksπ
