Hi, I have a problem, I can't control my new Beocenter 2 with my old Beo 4. (It's the new Beo4 with DTV-button) If I push DVD, and then try to do something, nothing happens on the Beocenter unit. The remote works fine with the TV. Is there a trick that I don't know about? Any settings?
Beocenter 2 and Beo4
Did you change options maybe? Do you have speakers connected to TV or BC2? It could be that maybe you somehow messe dup the option settings and that is why the BC2 doesn't react.
http://www.beoworld.org/beotech/mlsetups.htm
Does the BC2 still react to the CD command?
Cheers
JK
hold red spot butten and then press "list" butten
release red butten...
then press "list" butten again ... displayed "option" then press"go"
press again "list" butten ......display " A.opt" then press 0,1 or 2
if you have BV?.. display "V.opt" then press 0,1 or 2
depend on what option you have it
try it .. each number. 1 or 2 or 0
how you connect it .... you tv, sound, center 2.....do you cannect to beolink cable?
it's not easy to ...
do have socket unit manual? page 10.. you can see it
you can download it
here is
Hi, and thanks for help. I have speakers, but they are not connected now. I have a beovision, how do I connect it? Do I have to use a masterlink cable? I don't have one now. I have the manual, and It's the same manual as you link to. Page 10 is about radio tuning? Thanks for the help so far, haven't been able to test your hints. I will try later to day. Thanks again.
not a beocenter 2... page 10
check it "socket unit" manual p.10
I'm beginner, too but you are really is... well
let's find out...
which model tv, speaker, cable you have it?
Absolute a beginner, Beocenter 2, beovision 6-26, Beolab 8000 Powerlink from Beocenter to Beolab, scart from Beocenter to Beovision.
Ok, new problem, I was trying this, with the options. The beocenter is not connected to the Tv now. I was able to control the cd with the beo4, then I tried the optionsettings, the display showed sound, and now it doesn't work at all....
Beolab 8000 Powerlink to Beovision .... beocenter scart to beovision
A.opt o V.opt 2
try it
did you check beovision manual page 6?
