Beo5 warning!!
Whatever you do, do not break the glass on your Beo5! It costs over $500 to fix!!! 😡
That's ridiculous
That's really absurd! You can buy a new Beo5 for 350 euro's.
Did you pay the 500$?
You sure you're not getting "ripped-off". I think there's been several broken displays here on the forum, and I guess we would have heard about the absurd price?
Or is this due to the BEO5 getting replaced by BEO6, and spares are getting expensive.
The Beo5 is $900 here...
The price is from the authorised B&O service centre. Does anyone know where I could get the part cheaper? They say the part alone is $480!!!
As far as I understand, the display part contains almost all of the guts of the remote. After the repair process, you should essentially have a new Beo6, with wifi and all the future possibilities it brings. If they are really replacing the entire display and not just the glass, that is.
(I thought you couldn't even buy a new Beo5 anymore?)
If , as quoted above, there have been several broken displays reported on this form and bearing in mind that not all owners will be on this forum, what does this say about the Beo5's glass display, or more to the point, its stability?
I am assuming it keeps falling off or is knocked off where it is being placed. IMO, it always looked a prime design to be unstable!
I wonder how many have been broken and at what cost?
Keith Saunders a couple of weeks ago infomed me through this forum, any beo5 which breaks had beo6 parts fitted complete with wifi etc so effectivly changes to a beo6.
malcolm
The glass screen for the Beo5 is no longer available. The replacement Beo6 screen (which contains the Wi-Fi parts) will not fit on the existing Beo5 "ball". That means that the ball has to be changed as well.
Opman
I have 2 that need replacing.
The first one is purely missing the glass. The display works and the remote works perfectly, just no glass cover.
The second has a faulty touch screen. It doesn't respond to commands properly and when you press the screen it goes sort of 'jittery'.
My 3rd Beo5 has the arrows coming off the keypad. This is $300 to replace!
The service guys say the parts are available.. There was no mention of it becoming a Beo6!
Forget it, get one on ebay, they sell around 350 Euro in a mint condition and you can resell your damaged one for spares...
I have a mint Beo5 for sale at the moment and the price went up pretty quickly...
Rgds
Stephan
