BEO5 and SKY Q
I have just replaced the battery in my BEO5, thanks Stefan for the battery source and Keith for the guide, and have now tried to modify the commands to control SKY Q via the PUC. Mostly working well apart from two issues:
1) I cannot seem to get the BEO5 to send a select signal via the PUC to select a program to watch or a recording to play.
2) I cannot get the recordings to fast forward or reverse, just jump in increments.
Any ideas on what to do?
Paul
Hellol just seen your post, one question where can I find a b
soryy a battery and program my both BEO5 ? best regards
also I'v Two different type of B05 where to find the diffrences
B.R.
I bought mine via Amazon Germany but cannot find much of the details. I suggest you do a web search for a BEO5 replacement battery. Paul
hi
can you help me to configure beo5 to control SkyQ?
Thanks in advance
Best regards
