Probably your BEO4 has an older SW. For the moment, i'm afraid, I have no clue.
hfat
hfat
I suspect that the Beo4 has keyboard problems. The remote is faulty.
As far as I know, there is no way to disable the buttons on the remote and no way to enable them.
The setting up functions on the remote merely control what additional functions are present when you press LIST (a quicker ADD/REMOVE function)
View the IR emitters with your mobile phone camera and press the offending buttons - you should see the IR diodes emit the signal if the buttons are working.
Thanks everyone for the help, doesn't look like there is an easy answer though.
Might look for another Beo4.
I did it shows several of the buttons are not working :-(
