BEO4 setup - radio, cd, a tape functions don't seem to work?
Trying to set up a beo4 previously only used with a MX4000, I've tried the List+Standby button then selecting option then a.opt and 1, the light on my beosound 1 then blinks.
However, only the TV, Sat, V Tape and Light buttons seem to work I'm getting nothing from Radio, CD, A Tape, Record or AV, could someone tell me how to reanable these buttons?
Many Thanks Again!
You will need to put it in option v opt 2, then you should be able to bring through your cd radio :)
Thanks kai, I've tried to do this but it doesn't seem to have fixed the problem.  But I'm really new to all of this and might have done something wrong. [:'(]
Are video and audio sources connected by Masterlink or separate systems?
Sorry, I should probably have described this more clearly, I'm trying to use a beo4 with a beosound 1, but the aforementioned buttons don't work and therefore I can't operate the beosound 1.
I've recently purchased the beo4 off someone who has exclusively used the remote with an mx4000.
I wondered if I had to add a.setup?
I only have one B&O unit the Beosound 1
I just tried a.opt 1 on my Beosound 1 and all worked fine. Your Beosound 1 works fine using the bittons on it, correct?
Works fine using the buttons on it.
Hello,
I think you should try to use a different audio config for the beo4. Setting A.Mode or V.Mode configures the device how it responds to IR commands and not the BEO4 which commands it sends:
Standby+List
select Config
select Audio
select Basic.
It's worth a try. (BEO4 guide, page 14)
hfat
Thanks hfat
When I press Standby+List I only get three options
Option?
<press list again>
Add?
<press list again>
Remove?
I don't seem to get the option to select Config?
Is this hidden?
