Beo4 Remote Stand
Looks pretty dam good to me, what does everyone think?
I am not that sure about its shape to be honest. I would also have preferred a matt finish to
match the beo4.
how does it prevent scratches on the beo4?
looks homemade to me, and a little too fussy, and that stupid little triangle cut-out incase you forget the remote is bang & olufsen.
the concept is great, one shaped piece of metal ( i agree preferbly brushed or matt) , for me id prefer clean straight lines.
it may make a good doorstop but again for me its too fussy for that๐Ÿ‘Ž
i think the "designer" ( for want of a better name) has only ever seen the remote from b+o๐Ÿ˜
jay
Don't like it. But maybe if you can use the cut out triangle as bottle opener....
If the triangle was a rectangle instead, I'd like it. It just looks a bit contradictory to the Beo4's more straight-edged design.
Hi Corvin. I agree with you it looks cool. Perfect to have on the table ๐Ÿ˜
that stand does not look like B&O at all. I don't like it.
Me neither. The lines of the metal are quite nice, but don't go together with the straight lines of the Beo4. I also agree with Alex, the triangle thingy looks a bit silly, and yeah it should be a brushed metal not shiny.
See guys, this is why we get B&O to do the job - nobody else can.
I agree - half a Kilo of chromed brass doesn't quite do it for me I'm afraid๐Ÿ™
The concept is OK though.
Chris.
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
