Beo4 remote and the Core
Actually ir recevers only work on on the mkll
Both versions however the old only receives you cannot press
Ich havethe 1636 Receiver with Timer, Play and the up-down Button. This Model doesent Work. do I still have to make settings on the core? The model with the joyn button works well. There is still a model without a button, maybe this model works?
If you look somewhere on the Forum maybe MM knows from which number it is a MKII.
If you use an IR you might have to put it in option 1-2 or 6.
I am 100% sure that both ir models so join and the old work. But with the old you need to use the remote. Eg a BEO 4 or BEO 1 in ir mode.
Copy/paste from another theead here:
’Core Mk II has Type No. 3051 (look at the bottom of the Core (or via app / product configuration webpage)).’
