Considering a B&O Core. Have a Beosound 4 which I operate with a Beo 4 remote control. Does anyone know if the Beo 4 remote will operate the Core. Would be nice and simple to control both sound sources with one controller. (I know the Core can be operated by the B&O app.). Many thanks.
Beo4 remote and the Core
There is a version of Core where you can connect the B&O IR-Eye. I know that you then can control it with the IR version of BeoremoteOne and would assume it works with Beo4 as well.
@ elephant NOTE! New Mark II of BeoSound Core: BeoSound Core with IR Type No. 3051. BeoSound Core version without IR type no. 2797. (should now be sold out in DK).
Encouraging. Many thanks.
Getting better. Knowledge base building. Cheers.
Thanks Lawrence and PeterPan. The detailed info on version number and the link more than I expected.
Thanks Beo world forum.
Sorted.
which IR receivers work with the Core MK2
Cu Mailer
